Pro Tips #77
As the holiday period has settled in, its time to enjoy that time where tickets drop to an all-time low and catch up on what you might have missed in 2025 with the most popular Pro Tips of the year. It includes a mix of automations, new dashboards, overlooked data points and more!
Intune Automations
Ever wished you could stop guessing which Windows devices are enrolled in Intune, and just know, directly inside Lansweeper? Pro Tip #64 shows how to use the Microsoft Intune connector in FlowBuilder to pull in Intune device details and write them into custom fields (enrollment status, compliance state, last sync, IDs, and more), giving you a cleaner foundation for compliance and targeting.
New Dashboards and Custom Fields
Pro Tip #62 walks through building a BI Dashboard that turns custom fields into something you can slice, filter, and investigate at a glance, so classification work starts paying dividends in ITAM/ITSM/ITOM.
Deploying IT Agent with Intune
Want a straightforward way to roll out the new Lansweeper IT Agent across your environment with Intune? Pro Tip #68 breaks down the deployment flow (packaging, Intune app setup, verification), and also clarifies what makes IT Agent different from LsAgent, like direct discovery results to your Site, cross-platform auto-updates, expanded device data, and silent installs across Windows/Linux/macOS.
Aggregated Asset Insights
Are you an MSP? Pro Tip #65 digs into aggregated reporting and custom views in the MSP Multi-Site context, running reports across all managed sites (with Site ID included), monitoring asset/software changes (like what showed up in the last 7 days) and more.
Finding Software Version Drift
Ever look at your vulnerability list and realize the real culprit is… tiny version differences everywhere? Pro Tip #76 tells that story (with holiday flair), then shows how to surface “version drift” clearly with BI Dashboards, and how to pair it with FlowBuilder so drift doesn’t quietly rebuild itself right after you’ve cleaned it up.
