Blog
Smarter Infrastructure Monitoring: How Paessler PRTG Uses Lansweeper to Suppress Noisy Alerts
2 min. read
26/01/2026
By Elizabeth Massengil
Partners & Integrations
Blog-4-PRTG-Smarter-Infrastructure-Monitoring
The Challenge: Alert Fatigue from Decommissioned Devices
PRTG Network Monitor excels at performance monitoring, but many users faced a hidden challenge: legacy or decommissioned assets still being monitored. These inactive devices continued to trigger alerts even after being removed from production. The result? Alert fatigue, wasted investigation time, and distracted ops teams unable to confidently prioritize real infrastructure issues.
For monitoring platforms, knowing what not to monitor is just as important as knowing what’s online.
The Integration: Lifecycle-Aware Monitoring via Lansweeper’s Asset Intelligence
To solve this, Paessler integrated PRTG with Lansweeper using the Lansweeper Data API. A custom polling script inside PRTG queries Lansweeper for asset lifecycle indicators, including “Decommissioned” status and “Last Seen” timestamps for each monitored device.
If a device is flagged as decommissioned in Lansweeper or hasn’t checked in within a user-defined threshold (e.g., 30+ days), PRTG uses its public API to pause or disable corresponding sensors. This filtering logic can run on a scheduled basis (e.g., every 15–30 minutes) or be triggered in near real time using Lansweeper webhooks tied to asset updates.
The result is a dynamic alert suppression mechanism that automatically adapts monitoring scope based on actual infrastructure status, not assumptions.
The Outcome: 50% Reduction in False Positives
With Lansweeper providing reliable lifecycle data, PRTG users report eliminating up to 50% of false-positive alerts. Monitoring dashboards are cleaner, and engineers spend less time chasing irrelevant issues. This boosts confidence in alerting systems, improves Mean Time to Acknowledge (MTTA), and helps teams shift from reactive firefighting to proactive infrastructure management.
More importantly, teams now know exactly which devices are active and which should be left alone.
Explore Lansweeper for free.
No credit card required.
Need help evaluating?
Talk to sales
Clear pricing as you grow
View plans & pricing
